Need help fast water in intake
Old May 21, 2007 | 01:37 AM
albothug969's Avatar
Default Need help fast water in intake
I have a 2001 eclipes v6. i drove it up to ct from florida it was raining alot and water got into my intake. my gas has been bogging out and doesnt idle right.my check engine light was on and the computer said cylinder miss fire. so when i pulled the spark plug out of the first cylinder it pretty wet. so i went and changed it and got the check engine shut off but the car is still running like ****. does anyone one else know wut it can be and how to get my car to runn normal again
Old May 21, 2007 | 07:32 AM
Dusty Eclipse's Avatar
Default RE: Need help fast water in intake
Well, this exact same thing happened to me... In Florida, no less... NOt to scare you... but.. I ended up having to replace the engine. Hydro-locked. Water doesnt compress, man...
Old May 21, 2007 | 08:37 AM
Reset the ECU by taking the battery off for 10 mins. Put the key in the ignition to drain any excess power. Then reconnect it.. and drive it around a little.
Old May 21, 2007 | 08:53 AM
Ifail tosee how that will get water out of the cylinders...
Old May 21, 2007 | 08:55 AM
Ok... take the spark plugs out and crank it. Thats how you get it out... but after that you need to reset the ECU... then ifthat dosent work.. you have a major problem
Actually it might be the MAF
Old May 21, 2007 | 08:56 AM
Now Im with ya, Seb. Good call. Im willing to bet this wont end well, though.
Old May 21, 2007 | 10:53 AM
ill try all that and tell you how it works thanks
JohnnyK
Jun 2, 2011 01:10 PM
Silver00GT
Apr 8, 2009 08:47 AM
ProjectDrknss
Aug 9, 2007 01:39 AM
rses
Jun 19, 2007 04:39 AM
mountaindewguy
Nov 14, 2006 09:22 PM
