No gears working!?!
Old Oct 6, 2015 | 12:15 AM
sabrinaparks37's Avatar
Default No gears working!?!
Somebody please help, I have a 2000 2.4L straight gear eclipse. Recently, when I'd step on the gas, the RPM raises all the way to red line but the car isn't going faster, one night went up hill and was going 25 in 4th gear so I stepped on it, but it didn't go anywhere, so I put the car in neutral, and cut it off and back on, tried to put it in gear but they all acted like they were locked up? Finally got shifter in a gear but it was acting as if I was in neutral. Cars runs great, no leaks or problems leading to it, please help!!
Old Oct 6, 2015 | 07:42 AM
Guyfromhe's Avatar
Do any positions on the shifter work? It could be a cable or linkage issue...is this an auto or manual?
Old Oct 6, 2015 | 11:57 AM
No positions work and it's a manual
Old Oct 6, 2015 | 02:48 PM
Guyfromhe's Avatar
Does it feel like it's actually going into gear? making any noises?
Did you try playing with the clutch to see if that has any effect?
Old Oct 6, 2015 | 03:16 PM
After I cut it off, and back on, the gears were going into place and I could hear them going where they should be, but I'd press the gas and the car just acts like its in neutral, I assumed the clutch works since my car turns on but then again I don't know if that's just a sensor that turns it on or what
Old Oct 7, 2015 | 08:06 PM
Guyfromhe's Avatar
There is a clutch safety switch that will prevent your car from starting but that's electrical and has no impact on if your clutch is working or not.
I've never actually owned a manual so I'm not expert on the subject but if it feels and sounds like the gears are engaging and just no power is going to the transmission I'd say it's more than likely the clutch... The pad could be worn out or it could be stuck in a position where it's not transferring any engine power to the transmission... How many miles do you have on this car and when did you have the clutch last serviced?
Old Jan 5, 2016 | 06:45 PM
Ithaca69's Avatar
Sounds like your clutch is shot
Black98
Apr 16, 2005 07:23 PM
Black98
Mar 21, 2005 12:39 PM
gambit_710
Mar 20, 2005 12:18 AM
claude76
Aug 19, 2004 04:59 PM
jamarno
Jun 29, 2003 02:42 PM
