serious help!!
Old Jun 21, 2011 | 12:18 PM
unforgivenlife1986's Avatar
Default serious help!!
2003 mitsubishi ecllipse spyder gts 3.0
Recent repairs: valve cover gaskets, spark plugs, maf sensor, and air filter.
Problem: after thiis job has been completed later that night I was experiencing major problems. At a cold start I would start the engine let it warm for a couple mins when I puut it in either reverse or drive it revs the engine up to about 1200 rpms then jumps into gear. Also as I'm driving it I will notice it revs up the engine as its about to enter the next gear. This problem goes away and rides smooth after 5 mins of driving. Checked trans fluid and level and that is perfect.
Any suggestions????
Old Jun 21, 2011 | 01:50 PM
sounds like a possible vaccum line issue. Have you checked to make sure you hooked everything back in
Old Jun 21, 2011 | 02:00 PM
I checked all the possible vaccum lines that I could see, checked all sensors to make sure they were plugged in properly, and changed all the small hoses around the engine just in case one of them were leaking.
bradsimmo
Feb 11, 2013 07:47 AM
jeremyk
Aug 4, 2009 11:44 PM
B.e.R.a.T
Dec 29, 2008 09:06 PM
Andreas Tabasko
May 18, 2007 11:16 PM
grotesque
Nov 7, 2005 12:47 PM
