4th Generation This includes all Eclipses built in 2006 and 2007.
Question about a cold air intake
Old May 23, 2008 | 11:13 AM
CALI_eclipse's Avatar
Default Question about a cold air intake
hey i have an 08 SE GT v6 and i have yet to find any intakes for my 08. All I could find just goes up to an 07. If you can give me some help as to where I can find a cold air intake...that would be good news..thankz
Old May 26, 2008 | 08:21 PM
sk8r_matt_2003's Avatar
Default RE: Question about a cold air intake
The cold air intake is the same for the 06 to the 08 gt.
Old Jul 30, 2010 | 05:32 PM
kdrizle40's Avatar
The only intake I could find for my '09 eclipse is an injen.Do you know anything about that?
Old Aug 9, 2010 | 12:50 AM
bluedeval03's Avatar
i have been doing quite a bit of research online, and by phone to several companies about there Cold Air Intake Kits, or CAIK. The Injen brand costs the most out of all of them, but I seriously think they are the best thing going as far as performance, and longevity of the vehicle they are made for.
Injen is the ONLY company I have found that actually dyno tunes there setups to stay fairly close to the factory MAF settings, WITHOUT getting the dreaded check engine light from the CAIK making the fuel run lean. They perform a baseline dyno reading before they start making a kit. The key thing is keeping the air/fuel ratio fairly close to what the stock setting is. This keeps the system safe and prolongs the life of the engine. A motor to lean will soon blow, a motor too rich is just a waste of fuel, but when you keep your a/f ratio close to stock limit, you stay safe.
here is the link for the 4cyl auto
http://www.injen.com/galleries/produ...867wMRTech.jpg
http://www.injen.com/docs/other/sear...elID=44&Eng=L4
Hope this helps you make a moer informed decision. I am a disabled vet, I have the time and resources to research before I "waste" my money on a product. I have a 2006 Toyota Sequioa that I am about to order an Injen kit for. Here is the dyno chart for the tundra, which uses the same intake setup as mine. http://www.injen.com/galleries/produ...hsallinone.jpg
if you look at the line that says WITHOUT MR TECHNOLOGY, that means they tested another companies CAIK set up to get those numbers. DOWNFALL, they wouldn't tell what brand they used to get that A/F mix. At a 14.2 Air fuel ratio, Injen made more torque, just a minor less hp with an A/F mix of 12.172. I find that impressive
Old May 12, 2011 | 09:18 AM
mach1219's Avatar
please dont beleive that crap. I once saw Injen claim a 30HP gain from thier intake alone. Dont even waste your time reading the propaganda. mass air flow sensors, oxygen sensors and fuel injectors are continuoisly compensating to run the engine efficiently regardless of any air filter "tuning" based on the mass of air present and the feedback from the 02 saying add more fuel or cut it back.
Old May 12, 2011 | 09:21 AM
mach1219's Avatar
oh, the reason im here is i was lloking for a intake kit as well, not for overblown performance claims, but to clean up the engine bay and lose the huge plastic box, scoop and resonator.
it apperas the injen is the only one available period? is that correct?
apw5060
Sep 23, 2011 08:00 PM
steve7672
15
Apr 20, 2007 01:17 AM
kaiba408
Feb 14, 2007 06:56 PM
kniel023
Dec 28, 2006 12:51 AM
jmaahs07
Sep 5, 2005 08:00 PM
