Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Power Keeps Cutting Out...
Old Jan 28, 2006 | 10:24 PM
brandoN^gsT's Avatar
Default Power Keeps Cutting Out...
I disconnected my amp/subs about a month ago. When I took them out, they were working properly, with no problems. I hooked them up this evening, and anytime I turn my radio up past 17, the power cuts, and resets itself. My battery light is on, and when I try to start the car, the battery is obviously stressing itself to keep the car powered. It'll turn over, but, again, I try to turm the radio up past 17 on the dial, and the tradio resets itself.
Now, does the radio have a mechanism to preserve the batteries life, or is my battery just crapping out? Thanks in advance for any help.
-brandoN^-
Old Jan 29, 2006 | 02:24 AM
Default RE: Power Keeps Cutting Out...
Can a mod please close this?
I went, and turned on my car, and it worked just fine...It kindda worries me, but I think it was just the battery. Thanks anyways.
Old Jan 30, 2006 | 08:06 AM
m3kgt_99's Avatar
If you read my post from before, I said that the reason that your head-unit will cut off when your car is NOT running (when you have your key on ACC) is because your battery only pushes out 12V DC. When your head-unit is up too loud, it is trying to pull too much current from your battery and it automatically shuts off. If you have your car running, the alternator pushes out 14.4V DC and it can also push more current out then your battery. Current should be around .9 amps.
Old Feb 3, 2006 | 01:02 AM
Well, now it doesn't cut out at all, even when it's on ACC. I can turn it on as loud as I want, lol. Thanks though.
-brandoN^-
5Tizzle
May 25, 2006 12:44 PM
horms12
May 10, 2006 07:40 PM
Richie
Nov 5, 2005 05:35 PM
hoona
Jul 16, 2005 05:06 AM
gstowner
Oct 11, 2004 03:17 PM
