Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Weak aftermarket radio reception
Old Feb 25, 2014 | 07:46 PM
djbillyc's Avatar
Default Weak aftermarket radio reception
Hi all..
I just installed an Alpine aftermarket stereo in my 2013 Outlander Sport with a bazooka tube. Love it, sounds awesome...
But.............
I noticed almost immediately that the radio reception is a bit weaker on some stations that were initially strong. Not a huge deal, because I mostly listen to the iPod.. but I would like to fix the issue..
My understanding is that after searching the web, that some newer cars have an antenna amplifier built in. I searched and found a picture of a harness from a 2010 and up. It shows a pin in the harness for an "antenna amplifier"
Should I be splicing 12v switched into this wire to activate the amp, and would it fix my reception problem?
Thanks!
Bill
Old Jul 20, 2023 | 09:37 AM
computsoft's Avatar
There is a wire for the power antenna. This is not for a antenna to go up and down this for an amp for your antenna. That needs to be powered. your radio should have a power antenna out too. connect those together and you should be good.
sohosun
24
Dec 5, 2023 04:11 PM
Estam
Jun 6, 2022 01:07 PM
Shannon McLaughlin
Sep 27, 2016 02:30 PM
mrbiccies
Dec 10, 2011 11:18 AM
Knaackers
Jun 21, 2004 05:42 PM
