Eclipse Frequently Asked Question Section This section is only for FAQs, not Q&A. If you have an FAQ reply to submit, contact a moderator or admin.
idle air conttroller
Old Apr 19, 2014 | 03:10 PM
Yahiya ALrifai's Avatar
Unhappy idle air conttroller
hello everybody........
i have the idle failure in my eclipse 97 gst turbo.....
what another car idle and water pump can fit it ??
i heard that the galant can fit somehow??
please answer me guys i need ur help cause im in dubai and no parts available in the agency in here
Old Apr 19, 2014 | 04:05 PM
jkeaton's Avatar
Take the IAC out and clean it. What's the watr pump got to do with it?
Old Apr 19, 2014 | 05:54 PM
yes bro...... the water pump is damage too....i found out tha galant 94 to 98 is fit well..... is that right ??
and also hyundai sonata ISC can fit in my eclipse too ??
is that correct ??
Old Apr 19, 2014 | 11:17 PM
mxmikie's Avatar
Old Apr 20, 2014 | 11:33 AM
bodies,,,,,,,,,, well ill check if its gonna work if i clean the idle.....
you guys what do you think cause i got advices from friends that i have to use the brake protect cleaner not the engine cleaner ((WD40)) for the idle ?
advise me please
Old Apr 21, 2014 | 05:49 AM
Guys I kwait remove the throttle and cleane the idle and still I have the same problem the car keep switching off when on P and the AC is working
Rather than that the RPM on 3000 omfg
What the **** I can do pleaaaae help
Old Apr 21, 2014 | 10:19 AM
Sell the car, clearly you have no clue.
yamahablaster8230
Aug 29, 2006 09:28 AM
1398spdr
Mar 16, 2005 07:29 AM
gsr94trycatchit
Dec 19, 2004 07:27 AM
