'02 Montero Limited Warning Lights (and noises...)
Old Apr 8, 2009 | 11:46 PM
misery217's Avatar
Default '02 Montero Limited Warning Lights (and noises...)
So I've had my '02 Montero Limited for about a year and a half. It has just rolled 70K and things have all of a sudden begun to go awry....
1st: Every time I hit the brake pedal, The "Anti-Lock" and the "Brake" dash lights come on with the announcing *beep* then goes off after 3 or 4 seconds, only to repeat the next time the pedal is depressed. This goes on for an indeterminate period of time (sometimes 5 miles - sometimes 30 miles). I had the pads changed and the rotors turned to no avail. Any suggestions?
2nd: Almost at about the same time, the brake pedal when depressed make a "squeak-squeak" sound (that's 2 distinct "squeaks" at a precise tempo). I've looked under there to no avail as well...
Has ANYONE had a similar with this or any other year model?!? Any and/or all suggestions/recommendations would be GREATLY appreciated!! The closest Mitsubishi shop is an hour or 2 away....
Thanks all!!
Old Apr 9, 2009 | 12:37 AM
humhai420's Avatar
sorry the only light i ever got on was the yellow engine light
that is a oxe=ygen sensor
the second one to be replced
Galanthighspeeder
Jan 26, 2020 09:19 PM
Jizza
Sep 11, 2013 11:23 AM
Maljisto
May 28, 2011 02:57 PM
misery217
Apr 9, 2009 03:57 PM
MitsuVen
Jan 7, 2007 09:55 PM
