03 galant missing when slowing or stopping
Old May 13, 2008 | 01:25 PM
speelman's Avatar
Default 03 galant missing when slowing or stopping
I have a 2003 galant with 170,000 miles on it that is missing/cutting out when it is in gear ie. stopped at a stoplight or stop sign. Oddly enough, when it is in park it doesn't do it. It will cut out a little on acceleration, but once i'm above 15-20 mph its fine and doesn't cut out until I come back to a stop. Any ideas on what could be wrong?
Old May 13, 2008 | 02:42 PM
dsm1990gsx's Avatar
Default RE: 03 galant missing when slowing or stopping
Your egr valve could be sticking which explains the stalling at stops.
Old May 13, 2008 | 03:24 PM
Check engine light?
Old May 13, 2008 | 03:32 PM
speelman's Avatar
Yes, its on.
Old May 13, 2008 | 03:35 PM
Go to autozone and get it scanned for free, and write down the codes, then post them here, and we will tell you what they mean, and what you need to do.
Old May 13, 2008 | 03:37 PM
speelman's Avatar
Will do. Thanks!!
Old May 14, 2008 | 08:23 AM
speelman's Avatar
Went to autozone and only two codes came up. One was misfire in #2 and the other one was from my gascap not being tightened properly. We just replaced the wires and plugs in it about 3 weeks ago. Should we replace them again?? Also, I guess they cleared the computer because the ses light went off and hasnt come back on even though its cutting out.
Old May 14, 2008 | 10:00 AM
dsm1990gsx's Avatar
Well if you just replaced the plugs and wires you might have a bad coil.
Old May 14, 2008 | 10:34 AM
speelman's Avatar
Ok, i'm a girl, so don't laugh....whats a coil?
Old May 14, 2008 | 11:28 AM
Its what you plug the other end of the spark plug wire into.
I am betting just one of them is loose, or someone didn't tighten a spark plug down enough, or maybe one of the boots on the spark plug wire isn't sitting right on the plug.
On a side note, what is it with women and leaving the gas cap off? lol
Sophie Hemmington
Feb 23, 2014 02:37 PM
srs244
Feb 24, 2010 07:51 PM
igotyourboob
Sep 24, 2008 06:09 PM
iwilli1169
Jun 17, 2004 08:09 PM
JamesRS
Mar 31, 2004 01:26 PM
