1995 Eclipse Syncro
Old Feb 6, 2006 | 09:36 PM
RedNight's Avatar
Default 1995 Eclipse Syncro
Hey everyone,
Im looking at buying a 1995 Eclipse and I just took it for a test drive today. While driving me and my dad encounter something that we where pretty damn sure is not normal.
You cant shift into first gear (yes its a stick) while the car is in motion or if the engine is reved up in neutral with the clutch in. Now it down-shifts and shifts into all other gears perfect. My dad said that its the syncro for the 1st gear thats probably bad.
When we took it back to the dealership the guy there said that some cars dont have a syncro for first gear at all. Is this true, or he just trying to make a sale? Any help would be awsome, thanks alot.
Brandon
Old Feb 6, 2006 | 10:02 PM
anko_kun's Avatar
Default RE: 1995 Eclipse Syncro
ok so it will not go in to 1st when it is moving at all or above a certin rpm
Old Feb 7, 2006 | 12:58 PM
RedNight's Avatar
Yeah, it wont shift into first with any type of wheel movement, or if the RPMs are above 1k (it idled at 1k).
Old Feb 7, 2006 | 02:51 PM
does the clutch feel good, Like its not burnt out. I remember my car used to grind going down into first but that was just a safety at higher speeds so that you wouldn't acidentally down shift to it going to fast. But jsut sitting there reving up the engine w/ the clutch in has me stumped
Old Feb 7, 2006 | 06:09 PM
anko_kun's Avatar
that makes no sence
Old Feb 7, 2006 | 06:10 PM
anko_kun's Avatar
that is most likley a prob u need to get it checked out before u do any thing els
Old Feb 7, 2006 | 08:18 PM
RedNight's Avatar
Yeah I called my local Mitsubishi Dealership today and explained to one of there mechanics what was happening, he said that its definitly a broken syncro on the first gear. So that solves that problem. Thanks for your help guys.
Old Feb 7, 2006 | 08:22 PM
anko_kun's Avatar
np glad to be of some help i think[sm=gears.gif]
Old Feb 8, 2006 | 10:18 PM
DSMTalonAWD51's Avatar
hey
Old Feb 8, 2006 | 10:19 PM
one way to see if the tranny is shifting as easily as i should be is to see if you can downshift into first while going about 20mph. if it cant thats a problem
mach1
Jul 22, 2004 06:52 PM
FlyRyde
May 11, 2004 01:57 AM
kenped86
Mar 18, 2004 09:30 AM
eclipseman97
Feb 23, 2004 03:06 PM
ulbesry
Jul 2, 2003 02:00 AM
