2001 Eclipse Gs Noise....HELP!
Old Oct 15, 2006 | 07:14 PM
mitsu_sc's Avatar
Default 2001 Eclipse Gs Noise....HELP!
OK BECAUSE OF THE RECENT "DROP" IN GAS PRICE I STARTED USING 93 OCTANE, I WONDER IF THIS CAUSED THE FOLLOWING AND IF NOT WHAT IS IT??? ABOUT A WEAK AGO I WAS ACCELERATING IN FIRST WHEN I HIT 4500 RPM'S THE CAR MADE A NOISE MUCH LIKE A BLOW OFF VALVE IT SOUNDED LIKE THE DUMPING OF AIR OR THE RUSH OF WIND, THE CAR QUIT ACCELERATING BUT THE RPM'S STILL WENT UP... SO I THOUGHT THE CLUTCH BECAUSE T DOES NOT DO IT WHEN I JUST REV THE ENGINE IN NUETRAL. BUT IT WILL ONLY DO THIS "AIR DUMPING" AT OPERATING TEMP AND NOT ALWAYS AT THE SAME RPM'S.. IS IT POSSIBLY A VACUM LINE. REV LIMITER. SOME KIND OF VAVLE ON THE INTAKE. IM LOST FOR AN ANSWER AND COULD REALLY USE SOME HELP. IF YOU'VE GOT ANY ADVICE I WOULD APPRECIATE IT! THANKS...
Old Oct 15, 2006 | 09:49 PM
Default RE: 2001 Eclipse Gs Noise....HELP!
caps lock button please. well i doubt the gas had anything to do with it, it sounds like a bad clutch to me. Sounds like its slipping. Do the rpms rev up normal or faster than normal
Old Oct 16, 2006 | 01:59 PM
mitsu_sc's Avatar
They rev up normally as i continue to accelerate. Do you think that the clutch would make a soud like that? Thanks for the help!
Old Oct 17, 2006 | 07:01 PM
mitsu_sc's Avatar
help!!!!!
Old Nov 10, 2006 | 05:24 PM
mitsu_sc's Avatar
okay does anyone else have any idead whats up with my whip?
kelvin89
23
Aug 15, 2018 11:30 AM
phils06gt
Apr 18, 2012 12:10 PM
yodapala
Mar 6, 2012 11:45 PM
crecord1
Jan 29, 2012 07:26 AM
cscout2001
Apr 14, 2011 08:23 PM
