2004 lance ignition problem???
Old Jun 9, 2012 | 03:49 PM
pullstart1's Avatar
Default 2004 lance ignition problem???
does anybody have any insite on 2004 lancer 2.0 one coil not firing,
changed coil,thinking possible bad ecu???? had engine installed,he could not get it running,i took car back and found one of the coil plugs on the crank sensor??replaced wire to where it belongs and it only runs on the other coil?????
Old Jun 10, 2012 | 07:59 AM
mxmikie's Avatar
you changed the motor cause a coil was not firing then you found out that the coil was not plugged in then you replaced some wire to where "it" goes and now it only runs on what other coil the new coil ?????
allallyouyou
Feb 12, 2012 11:13 PM
skidy1
Sep 11, 2010 06:48 PM
4g94T_gt28r
Jan 11, 2008 03:26 PM
bigpochi
Jul 6, 2007 11:46 AM
KenAEM
Jul 11, 2006 01:29 PM
