2006 Galant
Old Aug 17, 2008 | 12:38 PM
gurlsports6's Avatar
Default 2006 Galant
I have a 2006 Mitsubishi Galant with 36000 miles and yesterday morning I moved it from my garage to the driveway no problem. Started perfectly and everything. When I tried to restart it, it wont turn over. My odometer numbers are flashing, and my prestige alarm is going off. The only way to make it stop is by turning the key half way. I have no radio power or window power. The battery is putting out 12 v and my alternator 14. So what could it be? Any ideas would help a ton!!!
Kristen
Old Aug 17, 2008 | 01:49 PM
HandyPal's Avatar
Default RE: 2006 Galant
Clean and re-install battery terminals really tight. Check ground and other power cables for damage/corrosion. Test the battery using special tester, not just multimeter. Likely your battery needs replacement if anything else is looking good.
Old Aug 17, 2008 | 10:24 PM
andry's Avatar
if your battery is ok, this is your battery terminals problem.
jbrad4ou
May 4, 2010 12:01 PM
supra33202
Aug 8, 2007 02:27 PM
neoskunk
Sep 30, 2006 04:46 AM
flame0221
Jul 2, 2006 04:19 AM
lyn
May 19, 2006 03:48 AM
