2010 ASX how to bleed the coolant?
Old Dec 4, 2023 | 02:03 AM
aidanh1's Avatar
Default 2010 ASX how to bleed the coolant?
Hey guys, I've replaced the coolant temp sensor on my ASX and now I need to refill and bleed the system of air, I don't have a cap on my radiator so how do I bleed the system? Its right hand drive
Old Dec 4, 2023 | 02:35 AM
DibbyDibbyDJ's Avatar
On level ground, Slowly fill the coolant via the cap behind the radiator. I saw slowly, because that way you will not trap any air in the system. When full fit the cap tightly and run engine until cooling fan runs. Keep checking the heater for ho air coming out. If it blows cold you have air in the system, and will need to start again.
Old Dec 4, 2023 | 02:38 AM
aidanh1's Avatar
I don't have a cap behind the radiator, otherwise that would be very easy and I wouldn't have asked 😂 I've got a cap on my reservoir. Ut my radiator doesn't have any obvious caps or bits ontop to unscrew
aidanh1
Dec 1, 2023 10:58 PM
Huaje
Jul 4, 2011 12:48 AM
Huaje
Jul 4, 2011 12:46 AM
mactruck26
Sep 19, 2008 10:42 AM
