2015 outlander sport 2.4 AWD
Typo. This is a 2.0 4WD/AWD. Not a 2.4
Hi, need your advice please. Changed the front right axle boots this past weekend. Put the really long axle assembly back in and now have a leak at the seal right there where the axle goes in, I assume to the trans or transfer case. Also, when took the long axle assembly out, it came out from the trans/transfer case and about a half qt of yellowish oil leaked out
the axle seal on the trans/tf case doesn't look damaged.
Also, is there supposed to be a rubber ring on the axle shaft that goes in to the trans/tf case?
Lastly, couldn't figure out where to put more fluid in. I bought 80 weight tf case fluid.
Really appreciate your help
Thanks
Thanks
so i definitely jammed it in there as best as possible. feels like its all the way in. it does not come out very easily either. i turned it to make sure the teeth were lined up. drives fine.
but never the less, it still leaks...........so i assume the axle seal is bad. is this just the one outer rubber seal? is there any more seals inside that i would need? any o rings?
thanks.
thanks.
Michael Stovall
12-06-2021 04:12 PM
