2015 outlander sport 2.4 AWD
Old Dec 6, 2021 | 12:59 PM
ttv8m's Avatar
Default 2015 outlander sport 2.0 AWD axle seal leak on trans
Typo. This is a 2.0 4WD/AWD. Not a 2.4
Hi, need your advice please. Changed the front right axle boots this past weekend. Put the really long axle assembly back in and now have a leak at the seal right there where the axle goes in, I assume to the trans or transfer case. Also, when took the long axle assembly out, it came out from the trans/transfer case and about a half qt of yellowish oil leaked out
the axle seal on the trans/tf case doesn't look damaged.
Also, is there supposed to be a rubber ring on the axle shaft that goes in to the trans/tf case?
Lastly, couldn't figure out where to put more fluid in. I bought 80 weight tf case fluid.
Really appreciate your help
Thanks
Old Dec 8, 2021 | 10:10 AM
ttv8m's Avatar
how hard do you have to push the axle in to be sure its seated against the axle seal?
Old Dec 8, 2021 | 02:00 PM
DibbyDibbyDJ's Avatar
Quite hard. It should then click in and be very close to the seal
Old Dec 8, 2021 | 02:08 PM
ttv8m's Avatar
Thanks. Will work on that tonight and post how we did.
Old Dec 10, 2021 | 09:10 PM
ttv8m's Avatar
so i definitely jammed it in there as best as possible. feels like its all the way in. it does not come out very easily either. i turned it to make sure the teeth were lined up. drives fine.
but never the less, it still leaks...........so i assume the axle seal is bad. is this just the one outer rubber seal? is there any more seals inside that i would need? any o rings?
thanks.
Michael Stovall
Dec 6, 2021 04:12 PM
douglasnichols18
Nov 25, 2013 08:00 PM
07outty
Jun 13, 2009 03:42 PM
zero_Wheeler
Jan 3, 2009 11:06 AM
oh_what_up
Feb 5, 2008 10:51 AM
