3000gt timing question
Old Aug 6, 2008 | 11:04 PM
4g63talon's Avatar
Default 3000gt timing question
I just timed my 96 3000gt sl and for some reason the valves and piston hit. All of the timing marks are lined up, maybe half a tooth off on one of them. My question is, is there a possible head problem if the valves and piston meet when properly timed?
Old Aug 7, 2008 | 07:24 PM
dsm1990gsx's Avatar
Default RE: 3000gt timing question
Did the car run prior to the timing belt change?
Old Aug 7, 2008 | 08:49 PM
4g63talon's Avatar
Yes, I bought it off of someone who was driving it prior to me buying it. The timing belt jumped and bent all the intake valves on both heads, so I bought a used pair of heads online from a guy that said the heads were from a 1995 3000gt/stealth. The heads are in good condition, valves are not bent at all. I just re-timed the motor again and the valves are hitting the pistons still. What would cause the valves to hit the pistons if the timing marks are all perfect?
Old Aug 7, 2008 | 08:53 PM
dsm1990gsx's Avatar
How did you check if the valvesweren't bent w/ the used heads u got? Can you post pics of the timing marks?
Old Aug 9, 2008 | 03:47 PM
4g63talon's Avatar
I used gas to check for leaks in the valves, they were all fine. Any idea's why the valves would hit the pistons when the timing marks are all lined up?
Old Aug 9, 2008 | 08:40 PM
dsm1990gsx's Avatar
Can you post pics of the timing marks and the only thing i can think ofthat would cause that would be bent valves or something broke in the bottom end.
Are you sure its making contact b/c when you crank an engine by hand it'll get hard in some spots b/c of the compression stoke (if that makes any sense to you).
Old Aug 10, 2008 | 11:36 AM
Joel_CA's Avatar
Are you assuming the valves and pistons are hitting because of a loud click? It may just be your lifters ticking- some of which can completely collapse causing a very loud upperend tapping noise.
JJ
marshmallow746
Jun 10, 2022 10:20 PM
judien
Mar 9, 2018 03:41 PM
sherk
Mar 5, 2013 10:47 AM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
