3000gt w/ erratic idle need help
Old May 10, 2008 | 05:13 PM
zhoods's Avatar
Default 3000gt w/ erratic idle need help
Intermentint problem sometimes starts and runs fine, sometime will not idle on cold start. Mostly does it when at running temp. Wants to die alot while shifting and sitting a red lights. No power loss, no check engine light. Always worked on by dealership. Has anyone had this problem and if so please help. Thanks.
Old May 10, 2008 | 06:01 PM
Default RE: 3000gt w/ erratic idle need help
Spark plugs and spark plug wires.
Change them.
Old Apr 10, 2010 | 01:53 PM
Angela1969's Avatar
Default Voltage Drops When My 3000gt Heats Up
I didnt have any problems untill i changed the battery, now when my car heats up, and when i press on the breaks the battery voltage drops. This also happens at idle speed though its not offten. The car stalls when i back up, though only when the car is warmed up. I had my alternator tested and thats good, i replaced the starter as well as changed the battery terminals. The car runs great when its cold, I need help for i am unable to keep changeing out parts. I have an after market sterio system, and alarm installed and when i turn up the volume on my stero it shuts off the stero that is. Any ideas as to whats cauesing this to happen?
Old Apr 12, 2010 | 02:13 PM
Who installed the battery? It sounds like someone killed the alternator voltage regulator by attaching the battery terminals backwards.
I responded to your PM by the way.
Old Apr 14, 2010 | 11:32 PM
MitsMaster's Avatar
Off the top of my head, Im not sure if the alt has a fuse. Check your underhood fuse block. The larger square, clear plastic topped fused links. One of them may be blown. On the idle problem, you probably have a bad ISC (idle speed control) motor. First try cleaning the throttle body. Pull the air hose off where it attaches to the engine, Hold the throttle wide open, engine not running, Spray a little carb cleaner on the round disc then spray a bunch of carb cleaner on a rag and clean the disc and the bore all the way around where the disc touches.
frank101
Feb 12, 2012 10:58 PM
zncus
Nov 23, 2008 11:20 AM
zncus
Nov 10, 2008 06:24 PM
DaClipsa
Jun 7, 2006 12:08 AM
art
Jul 16, 2005 08:16 AM
