4g63t help
Old Aug 13, 2009 | 03:58 PM
chester22's Avatar
Default 4g63t help
i have a 4g63t in my talon, and when i go to start it up it fires up just fine and idles normal, but after a minute or so it runs like crap and wont accelerate past like 2000rpms at the most. What could be the problem with this? were thinking either the wrong ecm was put in before i got it or the fuel pressure regulator is bad. Also when we turn the crankshaft position sensor while its turned on, it will run decent for a little, but then would run like crap. i ran a scanner and the only thing showing up is the front o2 sensor which was unplugged when we did the scan, but was plugged in when it was running bad. i also did a boost test and found no leaks as well as checked the timing and it was fine too. we did a fuel test too and it is fine. any suggestions would be awesome thanks
Old Aug 16, 2009 | 01:07 AM
chester22's Avatar
bump for any suggestions
Old Aug 16, 2009 | 07:56 AM
dsm1990gsx's Avatar
What year is the talon? Try swaping out the maf w/ a known good one.
Old Aug 17, 2009 | 12:00 PM
chester22's Avatar
1995. thanks for the suggestion, seems to be coming up a lot
2GxFTWxMack
Jan 14, 2008 04:28 PM
xslim69
Sep 15, 2006 12:15 AM
BigSteve0034
May 20, 2005 02:42 PM
matt02708
May 2, 2005 12:02 PM
xblade
Nov 20, 2004 11:54 AM
