Help 4g63T
Old Sep 13, 2006 | 08:28 PM
xslim69's Avatar
Default Help 4g63T
i have a problem my motor has a ramdom miss fire, and cant figure out what could cause the problem. any ideas would be great.
Old Sep 14, 2006 | 03:17 AM
monkeybumburning's Avatar
Default RE: Help 4g63T
Could be the spark plug wires or the spark plugs
Old Sep 14, 2006 | 09:49 AM
which cylinder/cylinders? If its just one then its most likely just the spark plug/wires. If its two then probably coil packs. Also could be a fuel issue as well
Old Sep 14, 2006 | 02:34 PM
VR4GARY's Avatar
Check your valves. Sometimes what you think is a misfire is a bad valve or bad valve adjustment.
Old Sep 14, 2006 | 03:02 PM
well i was kinda going on the idea that he got the code from the computer saying random misfire
Old Sep 14, 2006 | 10:29 PM
xslim69's Avatar
wires, plugs,coilpacks,motor,Ecu are all brand new. it is a ramdom miss fire on all four cylinders, and dont know what is causing it to happen.
Old Sep 15, 2006 | 12:15 AM
Your car may not be getting enough air. Make sure that you're intake system is running right. You might also check your radiator and the coolant fluid.
chester22
Aug 17, 2009 12:00 PM
2GxFTWxMack
Jan 14, 2008 04:28 PM
BigSteve0034
May 20, 2005 02:42 PM
matt02708
May 2, 2005 12:02 PM
xblade
Nov 20, 2004 11:54 AM
