starting problems
Old Sep 14, 2006 | 05:31 PM
buck tussle's Avatar
Default starting problems
i have a 90 eclipse and it wont start. its getting gas, its not getting fire. i changed wires plugs and the coil packand i t still wont start it just turns over. could it be the ecu and if so where is it located
Old Sep 14, 2006 | 05:34 PM
Default RE: starting problems
the ecu is located under the glove compartment. Not sure if thats the problem though it is a posibility
Old Sep 14, 2006 | 10:33 PM
xslim69's Avatar
befor u spend an arm and leg for a ecu, check your camangle sensor,that tells the ecm when to fire so if it is bad your car wont start.
Old Sep 15, 2006 | 12:16 AM
monkeybumburning's Avatar
Check your multi port fuel injection relay too. It's a pretty inexpensive part before you lay down like $100 for a new ECU.
Old Sep 15, 2006 | 12:26 PM
Crank angle sensor
jp2000
Jan 1, 2012 05:21 PM
Sparky63
Jul 19, 2006 06:23 AM
emssniper
1st Generation
Mar 13, 2006 11:51 PM
cagiestbat
Nov 14, 2005 05:13 PM
Parker
Sep 23, 2003 01:27 PM
