94 vr4 trans in a 91
Old Mar 8, 2006 | 12:25 PM
willyfrphilly's Avatar
Default 94 vr4 trans in a 91
Would and 94 vr4 6speed bolt in to a 91 vr4 with a 5spd? If so what would be needed
Old Mar 8, 2006 | 01:30 PM
Default RE: 94 vr4 trans in a 91
i know that it is possible to convert from a 6-speed to a 5-speed but i am not sure what would be needed and how. I would just contact "NESpeed" on here because he has done something similiar with his stealth R/T.
Old Mar 8, 2006 | 01:48 PM
ORIGINAL: TheEngineer
well dont forget NESpeed did a motor swap from a 95 along with the 6 spd tranny. My guess would be yess the tranny will bolt right in but im not sure if the bottom end of the newer motor is changed any
Old Mar 11, 2006 | 12:15 PM
NESpeed's Avatar
Yes it bolts up.......but you need a list of other parts. You will need the shifter linkage, transfercase, front axles, whole rear end setup from the 94. Your 91 has a 18 spline tranny, in late 92 they changed over to 25 spline. Its not worth it in your case....sorry to tell you.
toddrs93
Jul 16, 2011 11:32 AM
woogie_07
Aug 11, 2008 06:35 PM
willyfrphilly
Mar 8, 2006 11:03 AM
willyfrphilly
vtf-1
Jun 15, 2003 05:50 PM
