95’ Eclipse Transmission problem
Old Apr 15, 2004 | 04:38 AM
Libra0281's Avatar
Default 95’ Eclipse Transmission problem
Ihave a 1995 Eclipse it is an automatic, the problem is the Transmission is sticking in 2nd gear. But it just started about 4 days ago, the weird thing is the Speedometer stopped when it started. Can anyone help with this problem, and if so how much am I looking attofix it.</P>
Thanks</P><edited><editID>Libra0281</editID><editDate>38092.1109722222</editDate></edited>
Old Apr 15, 2004 | 11:57 PM
evo VIII's Avatar
you are probably going to have to have the tranny rebuilt and if that is the case it will be pretty costly, my advice would be for you to take it to your local dealer and they sould be able to tell you after driving it.
Old Apr 16, 2004 | 12:01 AM
Spyderman9803's Avatar
Hmm....The transmission problem isn't related to the speedometer I don't think. Speedometer might be the guage cluster going bad or a sensor die. Get the transmission looked at as soon as possible. The worse it gets the more it will cost to get it repaired.<IMG src=smileys/smiley17.gif border="0">
Old Apr 16, 2004 | 12:39 PM
SpyderGS's Avatar
It's most likely a TCU problem then. The TCU and ECU work in conjuction on automatic cars, so i you have amalfunctioning TCU, it will limit the ECU in some ways. Such as the speedo not working correctly.
Old Jun 1, 2004 | 12:24 AM
ninja_zx7r's Avatar
Default RE: 95? Eclipse Transmission problem
have the output speed sensor check usually it causes the speedometer to stop working and the transmission to act out.
97teg415
Aug 13, 2009 01:07 PM
oj0hn
Feb 4, 2004 07:20 AM
clcrig
Jan 16, 2004 05:29 PM
Riktar
Jan 14, 2004 05:38 PM
crackhead365
Oct 27, 2003 05:31 AM
