99 mitsubishi galant 2.4L engine light on with jerking/hesitation/shaking
Old Dec 26, 2011 | 12:24 PM
mari_cf39's Avatar
Exclamation 99 mitsubishi galant 2.4L engine light on with jerking/hesitation/shaking
Hello all!
My name is Maribel and I have a 1999 Mitsubishi Galant 2.4L ES with 105,293 miles as of right now.
Yesterday, Christmas I was about to head out and go to the store. I didn't get to do so because my CHECK ENGINE SOON light came on. The car started shaking, as a put it on drive the engine started to jerk, like the engine wanted to quit but continued, it continued to do this really rough, I put it on Park and it slowed a little bit but the engine stayed rough with hesitation. I tried driving it around the block, the jerking and shaking got worse. I can't take it to the local Pep Boys because they are closed today. So maybe some one can help out a bit?
Let me tell you about my Galant:
I bought it in Feb 2011
In March, I took it to my uncle who is a mechanic; he changed the spark plugs, oil, air filter, and a cap because oil was leaking. FREE
In August, My brother's friend who works at Pep Boys changed the two bottom belts and the radiator, normal wear and tear, I didn't want to wait till it got worse. $
In September, I took it to a normal shop and received an oil change.
In November, I changed all 4 tires, front breaks, and front rotors. $$
About 3 weeks ago my timing belt ripped, so I had the timing belt, little belt that goes with it , censor, and crankshaft blade changed. $$$$$$$
Thank you
If you need more info let me know.
Old Jan 5, 2012 | 12:26 AM
bruno's Avatar
Try cleaning maf sensor or fuel cleaner should fix problem
ajl44
Mar 23, 2014 10:04 AM
bdavidson
Mar 16, 2011 02:16 PM
bdavidson
Mar 2, 2011 06:08 PM
pwitoslaw
15
Nov 14, 2008 08:58 PM
virtualmind
Oct 20, 2008 11:18 PM
