Alternator Hookup
Old Jan 15, 2006 | 09:34 PM
NeoInsanity's Avatar
Default Alternator Hookup
This is a dumb question but i own a 1992 Eclipse 1.8 L and i got a new alternator. I hooked it up and the engines turns but does not start. Im not quite sure if i hooked it up right. Can anyone tell me where all the wires go im thinking that the wire and connector that has like a black case around it is hooked up wrong where do i hook it up???
Old Jan 24, 2006 | 01:54 PM
NESpeed's Avatar
Default RE: Alternator Hookup
You need to check to see if the alternator is putting out power. It might not be the alternator at all. Check that and let us know.
Old Jan 24, 2006 | 03:20 PM
sounds like he might need a multimeter to test it
Old Jan 24, 2006 | 09:51 PM
Lil red's Avatar
Should be only one way to hook it up. did you remember to hook the hot wire to the alternator? its the red wire that should be put on the alternator output post.
Old Jan 27, 2006 | 02:40 AM
jenuine2381's Avatar
On the hot wire to the alternator. Do not take the spacer out if you do it will fry you alternator.
snookey318
May 15, 2011 04:18 PM
DaBearSox
May 8, 2010 08:32 AM
sarahjoan
Dec 11, 2008 10:31 AM
jerusry
Nov 22, 2007 12:06 PM
talonawd1995
May 25, 2007 04:29 PM
