Where to hookup electrical wires
Old May 5, 2010 | 03:53 PM
DaBearSox's Avatar
Default Where to hookup electrical wires
Just bought an aftermarket stereo/nav to install into my 09 Outlander. I also bought the METRA AXXESS ASWC UNIVERSAL STEERING WHEEL CONTROL and a Pioneer GEX-P920-XM so that I can have XM radio through the head unit.
I have installed aftermarket radios before but no other additional pieces where I need power. So I can solder the harness I am just unsure where I should wire the power wires for the above pieces.
The steering wheel control needs to be connected to a non continuous power supply so I figure I can just splice it into the power wire on the harness but any other options would be great.
The XM unit needs to be wired to a continuous power supply, I guess so that it can store your presets, that's just what the installation guide says. Any idea where I should wire this?
Also, where has everyone been putting the grounding wires?
Thanks!
Old May 6, 2010 | 03:08 PM
DaBearSox's Avatar
Well looks like I have found an answer to my question.
I can just use these http://www.posi-lock.com/posiplug.html
to tap into the switched and constant power wires on the head unit's wire harness...
Still wondering where people have grounded wire on the Outie...could I just tap into the ground wire on the harness?
Old May 8, 2010 | 08:32 AM
rip14's Avatar
I grounded behind the drivers kick panel.
Took the panel off, scrapped off a small spot of paint, and grounded it using a star washer.
snookey318
May 15, 2011 04:18 PM
sarahjoan
Dec 11, 2008 10:31 AM
jerusry
Nov 22, 2007 12:06 PM
talonawd1995
May 25, 2007 04:29 PM
NeoInsanity
Jan 27, 2006 02:40 AM
