asx 1.8 D gearbox grabbing in 1st gear
Old Dec 16, 2017 | 05:06 AM
Mr Mitsi's Avatar
Default asx 1.8 D gearbox grabbing in 1st gear
Hi All
I have an ASX which has run like a dream for 7 years it is a UK model on a 60 registration plate. The last four times i have used it the gear change to first or out of first has been stiff just a few times. It seems to lock in place, so i do not force it i dip the clutch again and it then operates as normal. Also when in neutral on the odd occassion it feels stiff when shifting from side to side before you select the gear. I took it to a local garage who clearly didn't have a clue but the fault was not replicated at the time.
For example on my last journey of about 60 miles it occured 3 times and I dipped the clutch again and it worked fine.
Can anyone please advise on what the issue may be and how it can be fixed.
Thanks for reading this thread.
Kind Regards
Mr Mitsi
gorgh
Jan 31, 2012 07:16 PM
radycles
Sep 13, 2008 11:07 AM
92_laser
Nov 7, 2005 02:54 PM
Angel_408
Mar 9, 2005 10:27 PM
Angel_408
Feb 14, 2005 12:01 AM
