Backspacing
Old Aug 17, 2005 | 09:40 PM
vinceaton's Avatar
Default Backspacing
Could someone tell me what the backspacing on my 2003 Eclipse GTS? Also, I would like to know the bolt pattern on the hub. I'm putting aftermarket wheels on it and I need to know how to order.
Old Aug 18, 2005 | 02:21 AM
proteusx301's Avatar
Default RE: Backspacing
Well if its 5 bolts for the wheel, then your bolt pattern is 5x114.3
Old Aug 29, 2005 | 10:13 PM
vinceaton's Avatar
Does anyone know the backspacing (or how to measure) for my 03 Eclipse GTS?
Old Aug 29, 2005 | 11:03 PM
Patrick's Avatar
Administrator
yes..
take a rim off, and lay it face down...take a yardstick, or anything strait and long enough to reach both side of the rim...not the tire...you want to create a level plain across the mouth of the rim....the measure from that level plane to the mounting surface of the rim. that is your backspacing.
Old Aug 30, 2005 | 09:31 PM
vinceaton's Avatar
Is the backspacing the same as offset?
Old Aug 30, 2005 | 10:31 PM
Patrick's Avatar
Administrator
yes, but sometimes offset is listed as a percentage...
Old Sep 1, 2005 | 09:38 PM
vinceaton's Avatar
The percentage of the offset is determined by the width of the rim, right?
GST1995
Jan 14, 2008 09:31 AM
localh
Jan 12, 2007 11:38 PM
JaysMontero
Feb 12, 2006 08:22 PM
Maximus99
Mar 12, 2005 10:30 PM
