bad clutch
Old Jan 31, 2007 | 12:17 AM
SpeedyRed85's Avatar
Default bad clutch
recently it seems like i've been having a harder and harder time going into first and second, i push down the clutch all the way but it still gets stuck and i have to force it through, anyone have similar problem?
Old Jan 31, 2007 | 12:28 AM
Default RE: bad clutch
Does it only do it in the first two gears? Does it only do it when your flooring it?
I would check your clutch fluid first. If that is fine then next maybe try and adjust your clutch pedal rod. Try bleeding the system to see if there are any air pockets. Also try and floor it in first to see if the clutch slips. Then from there its gonna start getting into looking at other stuff like a possible bad tranny syncros or a throw out bearing or master cylinder
nawgee
Oct 20, 2008 06:24 AM
asim281
Mar 30, 2008 09:46 PM
agallardo
Oct 1, 2006 02:07 AM
agallardo
Aug 21, 2006 10:24 AM
gsx man
Mar 22, 2005 03:07 AM
