Battery disconnected now wont idle Galant 2001
Old May 1, 2005 | 09:34 PM
lb's Avatar
lb
Default Battery disconnected now wont idle Galant 2001
Left interior light on over 10 day period.Battery completely flat. Disconnected & recharged. Starts fine and idles well for a time but then engine dies after it has run for a while. Any help.
Old May 1, 2005 | 09:44 PM
outlancer's Avatar
Default RE: Battery disconnected now wont idle Galant 2001
u need a new battery, most likely you killed a cell and thats the end of that one
Old May 1, 2005 | 10:17 PM
lb's Avatar
lb
Dont think so, fear it may be ECU based. Any handy way to test.
Old May 2, 2005 | 06:49 PM
outlancer's Avatar
do you need to jump it after the motor dies
Old May 3, 2005 | 12:58 PM
DSMTalonAWD51's Avatar
its not ecu based. Charge the battery again, measure the voltage, is it around 13 volts? If not you need a new battery. if its 13 volts, see if it dies again. when it dies, measure the voltage again. if your battery is dead again it may be the alternator.
Old May 3, 2005 | 07:49 PM
lb's Avatar
lb
Sorry been away. On the lash.
Anyway battery works fine starts great.
Engine fast idle's at about 1100 until it heats up then cuts out if iam driving in traffic if i down shift.
Have been told the ECU reset's itself after you remove the neg on the battery.
Have run up 230 miles since recharge.
Thanks for the interest.
Old May 4, 2005 | 03:21 PM
yes it resets itself but that doesnt cause any problems
mnerin
Dec 24, 2013 04:30 PM
mnerin
Dec 8, 2013 10:58 AM
Scott S Grizzle
Feb 17, 2013 06:35 PM
green
Sep 3, 2012 12:45 AM
geter-d1
Jan 27, 2010 08:20 AM
