car mortor bogs help
RE: car mortor bogs help
Is this a turbo? If it is, it sounds like you have something disconnected in the supply air. Check to make sure everything is connected between the air filter and the throttle body. If everything is okay, it may be dirty injectors.
its a NON turbo but that is what i was thinking off dirty injectors but sometimes if you have a Bad distrabutor it would do the same thing i would think but may be the gear box also i dont know but well double check again =0 thanks for the reply bro
