Check Engine Code T0303
Old Jul 7, 2007 | 12:51 PM
OldSchool's Avatar
Default Check Engine Code T0303
Have been told this is a code for surge engine is firing. The car had not been started for about a week and when started felt like it was firing on only 3 cylinders for about a minute and then smoothed out but the check engine light has stayed on, what is it and what does it mean?
Old Jul 7, 2007 | 01:02 PM
Dusty Eclipse's Avatar
Default RE: Check Engine Code T0303
Clogged injector?
Old Jul 8, 2007 | 08:22 AM
OldSchool's Avatar
Don't know, but could be a clogged injector that finally cleared itself. Disconnect battery to reset 'check engine' light?
Old Jul 8, 2007 | 09:11 AM
silvercoupe97's Avatar
I think you mean "P" as in PO303, correct Oldschool?
If so...
PO303
Cylinder #3 misfire*
Things to look at.....
Ignition coil / Spark plugs / Ignition circuit / Injector / Upstream HO2S / Compression pressure / Timing belt / Crankshaft position sensor / Air intake / Fuel pressure / Crankshaft position sensor circuit and connector / Bad tuning
Old Jul 8, 2007 | 09:14 AM
I could have been a dirtied plug in cylinder 3 that caused the misfire, then finally cleared itself?
Old Jul 8, 2007 | 03:56 PM
OldSchool's Avatar
I had my daughter stop at the local auto parts and they told her the code and she then told me the code, so probably P0303. Well, the matter seems closed at the time, the light went off and has not come back on and the car seems to be fine again.
Old Jul 8, 2007 | 07:24 PM
Cool beans.
The guy at the parts store probably had a speach impediment and he said "P" but made it sound like a "T", lol.
Old Jul 8, 2007 | 09:56 PM
OldSchool's Avatar
Don't even get me started on part store guys, the 4th time I went to a part store I got the right power steering hose for a car. Thank goodness they had the old one in their hand or it could have been more.
Eclipsor
Jan 25, 2022 03:08 PM
c577
Oct 16, 2007 12:03 AM
thehintons06
Aug 20, 2006 08:46 PM
akshayg
Apr 7, 2006 12:55 AM
oldmansgs
Dec 17, 2003 11:10 PM
