CONVERT TO awd
Old Aug 22, 2007 | 07:11 PM
kmauger07's Avatar
Default CONVERT TO awd
i have a 96 gs fwd...auto with a 420a...i would like to convert to awd but not sure what i will need to do..can i keep th 420 or should i jump to the 4g63..ive heard that engine swap isnt the easiest...what will i need to do to get a rearend to put in her..is there any body mods i gotta make??
[/align]
Old Aug 22, 2007 | 07:26 PM
Default RE: CONVERT TO awd
about 15 grand.. and a GSX parts car..........can i ask WHY?
Old Aug 22, 2007 | 08:43 PM
bestwiseguy's Avatar
The only plausable answer is, just cause. lol
Old Aug 22, 2007 | 08:51 PM
That has to be the most pointless thing ever. The car struggles to make power through the FWD drivetrain. I wonder what the whp of the AWD drivetain would be LOL! Like... 65hp... ROCKIN!
Old Aug 22, 2007 | 08:54 PM
Kaede.Noir's Avatar
Kids got *****.... i have a 420a, auto that i love to death, and im a few of the ones who believe that squeezing power out of it its possible...... but even i think... that awd? for such a fragil engine.... i mean.... i... i dunno, SILVER!!! is this possible???
Old Aug 23, 2007 | 02:15 AM
silvercoupe97's Avatar
There isn't any AWD tranny to connect to the 420a though. The only way to make a 420a Eclipse into an AWD one is to remove the old motor and replace it with a 4g63 and it's AWD components.
Man, what you get out of that motor in stock form is enough to get the car moving at it's current rate of speed. Even if there were AWD components that could connect to the 420a, it would just lose more power due to drivetrain loss/parasitic drag while cruising. You'll need a strong enough motor to pull/push a car along and ~118ish to the wheels isn't enough bro.
After typing this, I just saw Sebz post and I agree.
As for making a FWD Eclipse AWD, yes, you'll need to remove the FWD gas tank and replace it with a GSX/TSi AWD gas tank, replace the rear suspension components, replace the center bracket along the tunnel in favor of the AWD bracket for the carrier bearing, drill the holes for the rear suspension (already premade holes just need to be punched out), that's it in a nutshell.
Easy? Define easy and tell us your level of mechanical skill. Motor swap easy? Yes, if you know what you're doing and obviously no, if you don't, lol.
Worth the time and effort to do that motor swap in an Eclipse? IMO, no. There are already Eclipses that are AWD and turbo. If there's something that was done to your current car...take it off and put it on that GSX that you're eyeballing. Will it save you time, headache, and money to just swap? No, unless you have a garage with an TIG welder, plasma cutter, a lift, and of course the other tools. For Joe Schmoe, it will be a chore and it will annoy the begebeez out of you. Then if it's your daily driver, lol, you're SOL and you better buy a season pass bus ticket.
If you're just looking for around 250-ish to the wheels, slap on a turbo kit to your 420a, a large one to keep from burning rubber when you should be moving. That will bring you up to $3k-$4k (for a larger turbo). Add on to that the cost of stiffer motor mounts (or DIY), an LSD (to keep traction), stiffer shocks/springs (obvious), and if you want more power, add an upgraded fuel system, forged internals, valves, springs, lifters...and the list goes on.
I too believe there can be power made from the 420a and I too agree that the 420a is a weak motor.....in stock form as just about any motor is. Sure it will take more money to make it as fast as.....(insert car here)....but that's only because it starts out as a non-turbo car.
Is it a waste of time? Not if there's value in the owners head/heart.
WTF? How did I get on this soapbox?
Old Aug 23, 2007 | 02:30 AM
A general rule of thumb... if you have to ask a question about it being possible... you shouldnt attempt it.
Old Aug 23, 2007 | 03:57 AM
Dusty Eclipse's Avatar
^^^^agreed
Old Aug 23, 2007 | 11:15 AM
kmauger07's Avatar
danm yall..thaks..im just gonna stick to keeping my fwd...the 420a i had before i blew it up was amazing..i got alot of power out of it with no mods and was very suprised but then i put new flex plate on and when i pulled the motor alot of oil came out and my dumbass didnt put any back..so i ran her dry..guess i just gotta find a way to get some mad hp to my fwd 420a..
Old Aug 23, 2007 | 11:37 AM
wow dude this is just a retarded statement...please do some reasearch. there isnt much of a point to trying to get "mad" HP out of the 420a. Just buy a gsx. Im so tired of these threads where people cant use a search to find the same answer thats asked 923480234897 times a week
Outlaander
Nov 14, 2018 09:50 AM
tw0000
Dec 12, 2011 05:11 PM
hatchetman9449
Sep 4, 2006 01:43 AM
night_turbo99
Aug 7, 2006 05:10 AM
Tucson302
Sep 6, 2005 02:24 AM
