correct inflation for 17" tires???
Old Jan 7, 2008 | 10:17 AM
2003 Galant ES's Avatar
Default correct inflation for 17" tires???
I purchased an 03 Galant ES a few years ago. It came with 17" Eclipse wheels on it. The Galant manual and the sticker on the car has the recommended tire pressure for the 2 Galant sizetires (smaller than 17")
I can't find a way to determine the correct pressure for my 215 50R17 tires.
I just bought new tires and think thatI may have been under inflating the old ones (worn out on the outside edges)
Thanks
Old Jan 7, 2008 | 10:43 AM
Default RE: correct inflation for 17" tires???
it usually says right on the tire what psi they are rated for
Old Jan 7, 2008 | 11:39 AM
Why is there 2 posts on this?
Low 30s is fine
Old Jan 7, 2008 | 01:08 PM
ORIGINAL: Sebba
Low 30s is fine
that isnt always true. It depends on what tire you have on there. On a stock tire usually that is correct but if you have a higher rated tire, then you want to go more. For example if you have a tire rated at max 50psi then you should be in the 45psi range. This will give you less wear on the better traction and speed rating.
And also make sure to do the psi when its cold as you will get thermal expansion when its warmer
Old Jan 11, 2008 | 12:59 AM
redline3kgt's Avatar
on a passanger car that experiences little to no extra load, heat, friction, or stress than usual, anywhere between 32 and 37 is fine. Since I doubt you are taking this car to the track, hauling a trailer, speeding in excess of 120mph, or taking extremely hard corners, you would be find at around 35 psi.
Also, like TheEngineer said, make sure you check your air pressure often (at least once a month), especially when the temperature changes frequently from hot to cold to hot, etc.
Cuffy
Jul 25, 2008 06:40 PM
2003 Galant ES
Jan 7, 2008 11:38 AM
50ul }{4ck3r
Feb 18, 2007 07:56 PM
DeathCabForCutie
Mar 16, 2006 11:56 PM
