easy performance mods
Old Jul 9, 2004 | 02:49 AM
outlancer's Avatar
Default easy performance mods
does anyone know how to do little mods to help you get 1 or 2 extra hp. one example is off a ford taurus and bronco. there is a radiator hose connected to the throttle boty that creates excessive heat. you take it off and seal up the hose and you can feel the difference right away but mostly after you engine is warmed up
Old Jul 9, 2004 | 03:57 AM
RSleeper99's Avatar
Default RE: easy performance mods
What kind of car. Right when i got my Eclipse, i took off the air silencer/restricter. It should be at the end of your intake. Mine went to the fender of my car and just ended, so it was restricting a lot of airflow. Well after i got that off i could feel a difference. Plus it sounded alot different, in a good way. It sounded alot meaner and made it sound like i had alot of **** under my hood, even though i just got it. If you have any other questions, feel free to ask.
Old Jul 9, 2004 | 02:12 PM
Seth's Avatar
Cheap mod that will help CAI (cold air induction) will increase power abit placing the pod air filter to get max airflow. [sm=smiley20.gif]
Old Jul 9, 2004 | 02:18 PM
Prophet's Avatar
Cheap mod that you notice a diff.
Drop in a K&N filter.
Old Jul 14, 2004 | 05:32 PM
BurntGSX's Avatar
how cheap are we talking... and why would you want an extra 1 or 2 hp?? I understand that more is better... but for that... change your oil and fuel filters, dump in some injector cleaner, run premium fuel.. that will add 2hp, new plugs and wires, that should add a couple 3-5hp. to the crank, not to the wheels...I double you'd feel the difference though. intake will hold its own, but thats in the$200+ range, headers will dramatically increase flow and you WILL feel that and thats in the $250-$400 range... nothing for cars is cheap... expect, at least for my gsx, everything you want is $250+
jack.s
Sep 27, 2008 01:34 PM
60ftlol
Jul 9, 2008 09:20 AM
mikeedee
Dec 6, 2006 12:44 PM
UltimateGSX
May 16, 2006 01:59 AM
gpalton
Apr 22, 2005 06:37 PM
