Engine noise
Old Mar 3, 2011 | 11:09 AM
Emjonasson's Avatar
Default Engine noise
Hi!
Recently my Outlander 06 has started making a strange FRRRRRRRR sound when you start pushing the throttle. Not sure what it is but it seems to be coming from the engine. I have read around on some forums about annoying noises coming from their car but it is mostly about the hissing sound problem.
I went to the dealership and they didnt find any problems (Would suspect that they are not that competent). So I rather ask some internet friends that are far more experienced in car matters than me.
Any ideas? or atleast something to point me in the right direction.
/E
Old Mar 16, 2011 | 06:30 PM
mothman52's Avatar
First, does it only happen when you are moving or when you rev the engine in the driveway? Trying to rule out road noise/tires/bearings/dragging a piece of trash around/etc...
Old Mar 18, 2011 | 05:25 PM
Emjonasson's Avatar
I revved the engine while standing in the driveway and it still does the sound. It happens whenever i push the throttle. I accelerated hard on a fine road and put in neutral and took my foot of the throttle and the sound subsided until it dissapeared completly.
So all i know is that it happens when i push my foot down and it slowly subside until gone when i take my foot off.
Any ideas?
Old Apr 2, 2011 | 01:09 PM
mothman52's Avatar
OK, I forgot to ask: standard or automatic transmission?
Automatic, I'm assuming (always dangerous). It might be your torque converter. Are your fluids up to snuff, clean, topped up? Might be a transmission thing rather than an engine thing, even if it happens at a standstill.
If you decide your engine is the culprit, try to localize where the sound is coming from and that in turn will point to a reasonable cause. Have an assistant under the hood with a piece of hose to use as a stethoscope to try and zero in on it.
Let us know what you discover....
phils06gt
Apr 18, 2012 12:10 PM
1398spdr
Oct 20, 2004 08:52 PM
matt03es
Jul 29, 2004 04:04 PM
kylewatkins
Apr 19, 2004 11:48 AM
ricker625
Jan 18, 2004 04:38 PM
