engine swap 4g32
Old Nov 28, 2009 | 06:14 PM
crazylegs's Avatar
Default engine swap 4g32
Hello,
I have a question about swapping an engine in a bobcat skidsteer. I do not know anything about mitsubishi engines so please bear with me if I sound ignorant. I searched quite a bit here and other places and have not found an answer to this question.
A friend of mine has a 93 or there about bobcat with a 4g32 in it. It is worn out it was overheated really bad there is coolant leaking into the #4 cyl. and the compression is #1(115), #2(90), #3(50), #4(50). so it is a rebuild or an engine change. I found a 94 4g63, and a 1993 4g37(which I may not be able to get it has been spoken for and I am waiting to see if the guy buys it) presuming he does not can I use either one of these engines in the place of the 4g32 or is there another engine that I can use?
Is there some guidelines that I can follow on finding the right engine to replace the 4g32
Thanks in advance to anyone who can help.
Ben
Old Dec 22, 2009 | 07:27 AM
scritaxmad's Avatar
I have a 92 Diamante SOHC. I do not have a owners manual for my car. I think that it requires a special trans fuild. What type is it and where can I local it? Also, I thought that in this car the fuild had to be checked when the car was Not Running ? Is this correct. Thanks for any help !
Old Dec 22, 2009 | 07:08 PM
Obakemono's Avatar
Default Hmmmm
http://www.pilotengines.com/servlet/...idsteer/Detail
I think a rebuild would be in order if the parts are still good on the engine (head, block, crank). Changing the motor to a different type might need different mounts, hose hookups, ect. Just my .02 worth.
Rob
Old Oct 1, 2013 | 03:32 PM
rgs944's Avatar
Does anyone know any more about this?
Old Oct 1, 2013 | 09:00 PM
Akzle's Avatar
any engine will fit in anything if you have the skill, time, and money.
Personally, id just get a new head, check the block is flat, hone the cyls to round and drive on.
There isnt much hard about the 4g series, so any other would be a fairly easy swap.
Old Oct 2, 2013 | 07:51 AM
rgs944's Avatar
D0 you think the 4g32 block stay the same over the production run?
California
Feb 19, 2014 01:22 AM
rgs944
Oct 1, 2013 03:50 PM
PharmD
Nov 9, 2011 11:02 AM
ZVNJ
Jun 22, 2010 09:35 AM
mxer1
Feb 3, 2007 04:41 AM
