Front Brake Caliper Rubbing on Hub
Old Jan 1, 2012 | 02:56 PM
Dommy93jars's Avatar
Exclamation Front Brake Caliper Rubbing on Hub
I recently rotated my tires and discovered that the front brake calipers were rubbing up against the hub, the brakes don't make any noise but I am curious as to what can cause this to happen and if there is a way to fix it. As you can see in the picture i need to replace my tie rods.
Old Jan 1, 2012 | 03:59 PM
amitsu's Avatar
Is there play in the hub bearing? If the hub is worn that bad it likely is growling pretty bad. How long have the rotors been on there are they recent, maybe the wrong part.
Old Jan 3, 2012 | 10:13 PM
_93TSI_370+K_'s Avatar
Ditto what AMITSU said...if the bearing was worn that much or was that loose, you would hear the growling of the bearing or the wrong parts are installed.
Are there matching wear signs on the brake pad or caliper, that will be an obvious clue. What does the other side look like? Does it show the same type of grooving.
Old Jan 5, 2012 | 01:12 AM
There is no growling, both front brakes have the same grooving. After looking closer at the brakes i noticed there is wear on the brake pads and not the calipers in the same area.
SERPENTOR
Jun 11, 2014 04:08 AM
bhanot
Jan 15, 2014 11:41 PM
piotrekmile
Sep 21, 2006 07:18 PM
Nuggethead 420
1st Generation
Sep 27, 2005 05:19 PM
Ace2133
Sep 7, 2004 10:44 PM
