Fuse Blowing
Old Dec 17, 2011 | 11:19 AM
Robert Thompson's Avatar
Default Fuse Blowing
I have a 1989 Mitsubishi Montero Tudor (little hard top jeep) 4 cylinder. There is a 3 fuse block located just outside the battery box under the hood. There's a 60, 100 and a 30 amp fuse there. The 30 is blowing. I know it at least supplies the starter and ignition. I have measured the current on the 2 white wires at the 30 amp fuse. It's 12 volts and about 16 amps at idle. At about 2000 rpm's it reads 46 amps.
I've got a 100 amp fuse in the 30 socket in order to test it. Variable current drain ? I don't get it, alternator trouble ? Has anyone else had this trouble. Wires get hot (2 white) and 30 amp fuse blows as rpm picks up from idle ?
Thanks,
Robert Thompson
pomerjon
Jan 19, 2010 01:49 AM
BlackGalant
Apr 24, 2009 07:40 PM
nyc95gst
Jun 26, 2008 10:45 PM
nyc95gst
May 28, 2007 12:05 PM
eotlou
Dec 15, 2005 05:45 PM
