Heating Question
Old Oct 27, 2006 | 08:15 PM
durango's Avatar
Default Heating Question
My '96 Eclipse RS (420A) has a problem with the heating inside the car. You can start the car, let it idle to operating temperature, the heat works fine. If you do this when it's extremely cold outside, and begin to drive the car, the temperature guage drops to the coldest point, and it starts blowing COLD air. Could this be the THERMOSTAT?? I don't want to go through another WINTER without heat.
Old Oct 28, 2006 | 02:01 AM
Manybrews's Avatar
Default RE: Heating Question
sounds like a typical failed thermostat.
its a cheap repair, so its worth doing regardless.
Old Oct 28, 2006 | 12:24 PM
durango's Avatar
UGGHHHHH!!!!! I purchased the $12.98 thermostat yesterday. This morning I went to replace it, I found that there wasn't a thermostat in it at all. Problem solved. Hmmmm.... Must have been a half *** mechanic that rebuilt this motor. So as I went to place the NEW thermostat in place, I find out it's not the right one. Dammit!! If this motor is a true '98 Neon motor, then I guess I have to replace it with a Neon thermostat.
Old Oct 28, 2006 | 02:56 PM
durango's Avatar
Ok... Just replaced the thermostat. I had to use the Neon thermostat. Believe it or not, it was $5.00 cheaper. I never knew buying a car was supposed to be such a pain in the assets. Next project.
Old Oct 29, 2006 | 01:58 AM
haha wow thats pretty bad that they would just forget to put something like that in
Old Oct 29, 2006 | 01:41 PM
durango's Avatar
Yeah, there's no telling what else may be missing. I know the oil pan, and the valve cover gasket's appear to be missing. I really don't plan on putting a whole lot of effort into this motor. This Spring I would like to replace it with a Short Block. I'm not wanting to go too extreme, but would like it to have more get up and go than most.
I'd just like to say thanks for all the HELP!!
rosco pico train
Apr 25, 2008 06:14 AM
oh_what_up
May 22, 2007 06:49 PM
FSF8822
Jul 8, 2006 01:26 AM
pinchespider
Oct 7, 2005 06:17 PM
Audioquest
Dec 11, 2004 08:34 PM
