Help! no Start Eclipse 90
Old Nov 9, 2005 | 10:27 PM
edaddik's Avatar
Default Help! no Start Eclipse 90
Hi! i own a 90 eclipse and suddenly this morning it wont start?? batt. term. is a lil loose and corroded but cleaned it and still wont start! i only here a "tick" sound everytime i try to turn it on. HELP MEE PLEASE!!! what do you think is the problem?? is t the battery?? terminals???? starter??? what ya think??
Old Nov 10, 2005 | 11:46 AM
Sanguinius's Avatar
Default RE: Help! no Start Eclipse 90
It ticks? Have you tried jumping it yet? Sounds like possibly a bad starter soleniod... Try tapping the starteer with a hammer or wrench if it turns over then then you have a bad starter soleniod you'll need to replace the starter. And tap it a good one no light taps. Smack it good and try to start. That may get you through a few days but I wouldn't push it.
Old Nov 10, 2005 | 02:52 PM
Winshawn's Avatar
Loose terminal and corrosion? Your battery is dead. It was not getting a good charge because of the loose connection and corrosion. Clean the terminals with water and baking soda. Reconnect the terminals. Give it a jump and you are good to go. However, if your battery is more than 5 years old, get a new one.
Old Nov 10, 2005 | 06:30 PM
edaddik's Avatar
just wanna thank you guys!!! i'll try to change the terminals tonight and then maybe buy a new starter.. i apppreciate it a lot! by the way do you have any idea where i can find the location of the starterin my eclipse??
Old Nov 10, 2005 | 06:52 PM
Sanguinius's Avatar
The starter should be on the back, underside of your engine.
Old Nov 10, 2005 | 06:56 PM
edaddik's Avatar
ill try to look for it, and replace a new one. Ty so much
Old Nov 10, 2005 | 07:12 PM
FireDoc's Avatar
You are going to try the little (and free) things these guys suggested first right? It would be a shame to run out and buy parts without testing what you have.
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
cougarkid
Aug 22, 2007 01:11 PM
damonmlime
Jun 15, 2007 08:24 AM
claytonkobe
Jun 12, 2007 05:28 PM
