Help with sunroof leak
Old Sep 7, 2006 | 01:52 AM
98_GstEclipse's Avatar
Default Help with sunroof leak
My Eclipse has a pretty bad sunroof leak. Im not to sure if its the weathering strip or the passage for water. Everytime it rains my headliner gets wet right by the drivers side pillar. Does anyone have this same problem or has had 1 in the past and fixed it. Can any1 give me some advice on what to do. I called mitsubishi and the said its 90 for to check it out and then labor and parts
Old Sep 8, 2006 | 05:46 PM
blamesociety's Avatar
Default RE: Help with sunroof leak
oh wow 90 for that?? mine was leaking and was starting to peel the liner off the passenger side. they said that it was leaking from the weather strip and then that they had to replace the whole freakin' sunroof and that it would prolly cost like 200+ to fix it. i was like...bs we can fix that stupid **** ourself...damn satan...damn 'em...
Old Sep 11, 2006 | 01:36 PM
monkeybumburning's Avatar
I have the same problem with my sunroof. Should we just replace the seals? I've been told this is the best fix for this problem.
Old Sep 14, 2006 | 01:40 AM
Honestly I dont know Im guessin the seal 1st but I also heard after awhile the lil passage or w.e the water goes through when it leaks down the sunroof could be clogged. Hopefully its just the seal tho.
jthorn75
Jun 4, 2012 04:18 PM
itxmontero
Jan 31, 2010 06:41 PM
MrJayDeeOne
Aug 23, 2007 03:58 AM
cheryllynn
4th Generation
May 15, 2006 08:43 PM
SPECOPS
Jan 31, 2006 11:49 AM
