How to remove pins from side mirror harness?
Old Apr 11, 2017 | 06:22 PM
ikjadoon's Avatar
Default How to remove pins from side mirror harness?
I'm trying to get the pins out of these harnesses for the side mirrors on my Mitsubishi Outlander. What is the trick here? I tried pushing a thin, sharp metal screwdriver into seemingly every hole and tugging, but they are in stuck in there well.
Does the white casing need to be removed first? Do these harnesses have a name? It says PBT-GP15 on the side, but that's the type of plastic used, I believe. Any help or tips are appreciated.
Old Apr 11, 2017 | 07:24 PM
ikjadoon's Avatar
This is what the bottom looks like:
Old Apr 11, 2017 | 07:29 PM
ikjadoon's Avatar
And the wire end of it:
Old Feb 25, 2025 | 11:52 AM
Blue407's Avatar
Did you ever manage to do this? Its my job for the weekend as I have had to replace the whole motor due to mirror having a big hit from a van. (it smashed the mounting).
Old Feb 26, 2025 | 06:12 PM
ikjadoon's Avatar
Hello! Yes, actually. Thank you for asking.
If my memory serves me right (it's been some time), I just needed a smaller screw driver (almost the size of a needle, IIRC). That little screwdriver gets inserted into the back pin you want to remove and there is some location / latch that can get unlocked → the pin pulls out smoothly.
If my memory serves me right.
Old Feb 27, 2025 | 03:52 AM
Blue407's Avatar
Thanks, I have various little picks and a set of connector re-pin tools, so will give it a go this weekend.
Such a pain that the hole in the motor is so small, when googling for solutions I found many manufacturers either run the wires alongside the motor, or they have a large hole in the motor that has space the connector to go through intact!
1960StudebakerHawk
33
Feb 29, 2020 06:34 PM
JRK5892
Apr 22, 2013 06:12 PM
davidmitsusrock
Aug 15, 2007 12:54 AM
