Mitsu Diamante smog check, VAG-COM problem
Old Oct 9, 2008 | 01:24 PM
alavr002's Avatar
Default Mitsu Diamante smog check, VAG-COM problem
Just failed the CA smog check. The emission test results are OK, but Failed during VAG-COM check. The manual scanner connected OK, no error codes. But the certified scanner (connected online) could not connected properly. Sometimes it connected successfully, sometimes not. (They tryed 2 different scanners). The problem was with reading RPM from engine. It worked properly when that people demonstrated me problem after test!!!
Mitsubishi Diamante, 1997. 160000 miles.
Do you have any suggestions?
Thank you very much.
edaddik
Dec 11, 2020 09:40 PM
tom61
Apr 30, 2011 02:20 PM
akabeware
Dec 30, 2006 02:30 AM
inw_j_gsx
May 4, 2006 03:23 AM
FatalJRA
Dec 8, 2005 01:44 AM
