My car died on me today
Old Aug 19, 2011 | 08:25 PM
kenshi's Avatar
Default My car died on me today
I could use some advice here. I was driving down the road today and my engine abruptly cut out on me. There was no sputter or miss or anything. It was as if I had turned the key off, except for the electrical accessories still being on. The starter will turn over but it doesn't sound at all like it's trying to fire. A quick look under the hood didn't reveal anything obvious.
I've never had this happen before. I'm thinking it's a problem with the ignition system but I'm not sure where to start. How can I narrow down the problem? I have no other transportation so I need to get this running quickly. Thanks in advance.
Old Aug 20, 2011 | 10:59 AM
kenshi's Avatar
Can someone tell me where the fuel pressure valve is on this car? I've traced the fuel lines all under the hood and I'm not seeing it.
Old Aug 20, 2011 | 12:22 PM
kenshi's Avatar
I determined it is pumping fuel. The PCM is getting power because the fuel injectors are. If the anti-theft was screwing up, the starter wouldn't engage, right? So I'm thinking it's a sensor, maybe the crank sensor.
Old Aug 21, 2011 | 02:49 PM
kenshi's Avatar
Okay, can someone tell me where the crank position sensor is on the 3.0? I figured it would be near the crankshaft pulley but I don't see it.
Old Aug 21, 2011 | 02:53 PM
kenshi's Avatar
I forgot to mention it's a 2000 Galant.
Old Aug 21, 2011 | 04:47 PM
kenshi's Avatar
Nevermind. The timing belt broke. I'm probably screwed.
z80
Jul 2, 2011 01:12 AM
michaelsgst
Feb 27, 2009 12:08 AM
TheEngineer
Jun 23, 2008 10:32 PM
MrJayDeeOne
May 7, 2006 11:14 PM
Shadowplane676
Dec 23, 2005 08:37 PM
