Oil in the air filter on 89' Montero
Old Dec 30, 2004 | 10:46 PM
CoolHecC's Avatar
Default Oil in the air filter on 89' Montero
I need to pass smog here in Cali. Montero, 3.0 ,Right now I have oil coming out of the valve cover into the air filter adn into the engine. I have replaced the pcv valve and everything else looks fine. Thanks in advance..
Old Dec 31, 2004 | 01:10 AM
midnght's Avatar
Default RE: Oil in the air filter on 89' Montero
You can take off the valve cover and give it a new fresh sealant coat.
Old Jan 5, 2005 | 02:45 PM
CoolHecC's Avatar
I need to clarify a little bit, I think. The oil is coming out of the top of the valve cover where it connects into the air intake hose.
Then the oil runs down the intake hose and up into the intake.
Since posting last I did a smog pre-test. It Passed! So I had them do the real test not even 10 min. later, and I failed with gross polluter. Now I'm at a real loss any help is appreciated.
OutlanderGT
Mar 4, 2014 04:55 PM
lancer0594
Feb 5, 2009 06:48 AM
EclipseDood
Apr 27, 2006 11:11 PM
gsr94trycatchit
Dec 19, 2004 07:27 AM
