Outlander 2013 Roof Rattle
Old Jun 2, 2019 | 10:20 AM
Mo257cat's Avatar
Hi there I have the same noise coming from behind the light cluster in my GX4, I have located the bolts, but they seem to be as tight as they will go, I am worried about over tightening in case of causing a worse problem. It seems to me that the two pieces which are bolted together, may have had something between them and this has either dried out or something similar, as mine is worse during hot weather. Don’t know what your views are. Will have one more try to tighten the bolts and keep my fingers crossed.
Old Sep 14, 2021 | 10:51 PM
Cincy's Avatar
Originally Posted by Dave Barry
Thanks for the reply I took down the light cluster and tried different insulation tape etc but nothing seemed to work today I located 2 bolts attached to the roof and gave them a tightening and that seems to have worked fingers crossed
Thanks again
are you able to explain how you did this. I have the same issue.
catherineapop
Dec 18, 2012 01:07 PM
fiestataz
Jan 8, 2011 08:56 PM
Russk1978
Nov 23, 2010 11:45 AM
125matt
Apr 13, 2006 08:05 AM
ictponder
Mar 12, 2006 04:34 PM
