overheat unless a/c is on...WTF?
Old Jun 14, 2007 | 05:00 PM
Manybrews's Avatar
Default RE: overheat unless a/c is on...WTF?
your fans are obviously not functioning correctly. They're probably coming on with the AC as they should, but not during an overheat condition.
they're turned on by the PCM, but its doubtful that the PCM is the cause. Trace the wiring, relays, etc.
Old Jun 14, 2007 | 07:32 PM
livinglegend_86's Avatar
ORIGINAL: silvercoupe97
Coolant temp switch. There are two of them, one for the a/c (seems to be working just fine) and one for the fan. It sounds like your coolant temp switch is bad. I'm not talking about the coolant sensor that sends coolant temp info to the gauge. The temp switch usually has two wires leading to it, while the sensor has only one.
ok, so where is the coolant switch located at?
i was also thinking that it might be the little black box located on the actual fan... looks like a relay or something. is that it?
http://donherring.reachlocal.com/cou...26ei%253DUTF-8
maybe....??????
Old Jun 19, 2007 | 04:22 PM
ok, she had the car diagnosed, and it's the temp sensor.
now my question is... where is it located at? and roughly how much $ at a parts store???
tacole27
Oct 5, 2011 05:55 PM
Hartd23
Jun 30, 2011 03:50 PM
pdogg777
Mar 15, 2007 02:02 PM
PooT_Nation
May 15, 2006 09:47 PM
RCJr9186
Feb 21, 2006 11:29 PM
