overheatin problems
Old Aug 2, 2010 | 05:33 PM
EclipseGuy92's Avatar
Question overheatin problems
im having trouble with my car overheating when im idling the block is not leaking anywhere and every time i check the reservoir its bone dry and i cant find where its leaking if it is leaking?
Old Aug 4, 2010 | 06:47 AM
MitsMaster's Avatar
are the radiator fans running?
Old Aug 4, 2010 | 09:57 PM
dsm1990gsx's Avatar
Check the fans and see if they are coming on. Does the car smoke at all?
Old Aug 5, 2010 | 09:43 PM
Manda's Avatar
If it's only happening when you're idling the first thing I would check would be the thermostat!! If it's stuck or bad that will definitely make it overheat. Hope this helps.
Old Aug 9, 2010 | 05:22 PM
well one of the fans r on. and i recently replaced the thermostat
Old Aug 19, 2010 | 08:45 PM
dsm1990gsx's Avatar
Try doing a compression test.
Old Aug 20, 2010 | 05:43 PM
well some how it stopped overheating and is running alot better i seem to have done something right
jp2000
Jan 1, 2012 05:21 PM
p4c0
Feb 22, 2007 06:36 PM
