pcm problem
Old Jul 25, 2005 | 08:05 PM
eclipso's Avatar
Default pcm problem
Hey guys and girls. my problem is that i recently did the timming belt on my 1995 eclipse. i made sure all marks are lined up and every plug is connected. the car wont start , i checked for spark and fuel and is good i checked for compression and its also good, the only problem i could see would be the pcm because the shop manual says to check for voltage in the cam and crank positioning sensors which are good but i get no continuity at the certer prong for each sensor, which the book says there should be and if their in none the harness or the pcm could be bad i checked the harness for each sensor and they seem to be ok. If any one know how to reprogram a computer please let me know.(I already did the disconnecting of the battery) by the way the engine light gives me a code 12 which its supposed to be a fault in he stand by memory circuit.
fireeatn1
Jun 2, 2007 06:00 PM
oops129
Jan 4, 2006 04:38 AM
bigjermgtp
Oct 28, 2005 01:39 AM
eclipso
Jul 25, 2005 08:05 PM
John46307
May 21, 2004 07:01 PM
